COMPLETE 289 HIPO Motor, all Machine work completed - Ready to assemble
  • I sold my K Code convertible, but the new owner did not want the Motor I was working on (2 years of finding parts). the machine work was performed by an excellent engine builder in Maryland (I can give his contact info to any buyers if they have questions). I just picked everything up from his shop and decided to sell it to someone who needs it. Here are the details:
    All Machine work has been completed, the block is bare and .30 over - Mains aligned and honed, Balanced
    It is a VIN stamped motor, Dated B111 stamped 6R07K186586
    HIPO Heads rebuilt, mismatch date codes B-25-66, and J-30-65
    It has everything you need, except the intake, valve covers, and distributor
    Everything is ready to assemble including
    Machined and balanced flywheel w new tooth ring
    Correct HIPO connecting rods with Pistons and Rings installed
    Correct HIPO Main caps
    Correct Balanced HIPO Crank
    Correct CAM
    New lifters, screw in studs, correct Hipo Rocker arms
    Full gasket set
    New correct Oil pan
    Ford Water pump (needs to be rebuilt)
    I have a complete listing of every part that comes with this motor, along with a full invoice of all work performed. Full photos available upon request. Located in Frederik MD.
    I am probably in this motor for about $10,000.00, but I would let it go for less. Make me a decent offer and it could be yours. I can also have the machine shop assemble it for an additional $1,000.00 (aprox)
    Edited once, last by Kevinloe (April 29, 2025 at 6:09 PM).
