Display MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreHere is another Ebay auction for an NOS C0AF 12152 A dual point distributor breaker plate kit by Ebay member "mysunshine302" with starting bid of $135.00 and a Buy-It-Now of $175.50:
You are bidding on a NOS service replacement dual point mechanical / centrifugal distributor breaker plate setup. #D1AZ-12A132-A supersede #C0AF-12152-A. This item has been *obsolete from Ford for over 35 + years!!! ** FORD also used it as a conversion kit in the Boss 302 Trans Am dual point distributor. This full package comes complete as seen fully assemble in the pictures. NOS Motorcraft two piece steel plate & NOS Motorcraft service replacement dual points DP-5 & NOS Motorcraft condenser DC-6 & New stainless steel hardware all installed. All looks *New. No *corrosion on dual points or condenser. Also including Motorcraft installation paper. *Last one without the Motorcraft paper package &*Not the Motorcraft boxes in pictures. This is 100% correct for the 289 HiPo (K) code dual point distributor part number C5OF-12127-E or 427 HiPo (W) code dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane all mechanical / centrifugal advance. Also will work *100% to change any of the Ford V8 distributor engines from a *Single point distributor to a *Dual point distributor: 260, 289, 302, 351 cid.Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor aluminum housing from 1964 & up: FoMoCo & Autolite & Motorcraft. Correct fit for the 1964 to 1973 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with the Ford V8 engines & Ford V8 distributors.
Motorcraft 289 HiPo 427 428 351 302 Single Point Too Dual Point Conversion Kit | eBay
This NOS C0AF 12152 A dual point distributor breaker plate received no bids by May 28, 2022 and therefore did NOT sell.
This NOS C0AF 12152 A dual point distributor breaker plate kit is back on Ebay again with the same starting bid of $135.00 and the same Buy-It-Now of $175.50:
This NOS C0AF 12152 A dual point distributor breaker plate received no bids by June 12, 2022 and therefore did NOT sell.
This NOS C0AF 12152 A dual point distributor breaker plate kit is back on Ebay again with a new much higher starting bid of $250.00 and a new much higher Buy-It-Now of $325.00:
Motorcraft 289 / 427 HiPo Dual Point Conversion Kit D1AZ-12A132-A. | eBay
This NOS C0AF 12152 A dual point distributor breaker plate received no bids by June 28, 2022 and therefore did NOT sell.
This NOS C0AF 12152 A dual point distributor breaker plate kit is back on Ebay again with a new lower starting bid of $195.00 and a new lower Buy-It-Now of $255.00:
289 HiPo Dual Point Motorcraft Conversion Kit D1AZ-12A132-A | eBay
This NOS C0AF 12152 A dual point distributor breaker plate received no bids by July 4, 2022 and therefore did NOT sell.
This NOS C0AF 12152 A dual point distributor breaker plate kit is back on Ebay again with a new lower starting bid of $175.00 and a new lower Buy-It-Now of $230.00:
This NOS C0AF 12152 A dual point distributor breaker plate received no bids by July 17, 2022 and therefore did NOT sell.
This NOS C0AF 12152 A dual point distributor breaker plate kit is back on Ebay again with a new higher starting bid of $190.00 and a new lower Buy-It-Now of $250.00:
289 HiPo Dual Point Motorcraft Conversion Breaker Plate Kit D1AZ-12A132-A | eBay
This listing for an NOS C0AF 12152 A dual point distributor breaker plate was ended by the seller August 30, 2022 with the following explanation "This listing was ended by the seller because the item is no longer available".
This NOS C0AF 12152 A dual point distributor breaker plate that was "no longer available" is back on Ebay again with a new lower starting bid of $150.00 and a new lower Buy-It-Now of $195.00:
!! Please take your time looking & read description fully !!
You are bidding on a NOS service replacement dual point mechanical / centrifugal distributor breaker plate setup. #D1AZ-12A132-A supersede #C0AF-12152-A. This item has been *obsolete from Ford for over 35 + years!!! ** FORD also used this conversion kit in the Boss 302 Trans Am dual point distributor. This full package comes complete as seen fully *assemble in the pictures. NOS Motorcraft two piece steel plate & NOS Ford service replacement HD dual points DP-5 & NOS Ford condenser DC-6 & New hardware all installed. All looks *New. No corrosion on dual points or condenser. Also including Motorcraft installation paper & the Motorcraft paper package. *Not the Motorcraft boxes. This is 100% correct for the 289 HiPo (K) code dual point distributor part number C5OF-12127-E or 427 HiPo (W) code dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane all mechanical / centrifugal advance. Also will work *100% to change any of the Ford V8 distributor engines from a *Single point distributor to a *Dual point distributor: 260, 289, 302, 351 cid.Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor aluminum housing: FoMoCo & Autolite & Motorcraft. Correct fit for the 1964 to 1973 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with the Ford V8 engines & Ford V8 distributors.
Motorcraft 289 HiPo 427 HiPo Dual Point Conversion Kit 428 351 302 Single Point | eBay
