NOS C0AF 12152 A Dual Point Distributor Breaker Plate
  • Here is another Ebay auction for an NOS C0AF 12152 A dual point distributor breaker plate kit by Ebay member "mysunshine302" with starting bid of $95.00 and a Buy-It-Now of $125.00:
    !! Please take your time looking & read description fully !!
    **This is the Christmas Early Bird Special**
    You are bidding on a NOS service replacement dual point mechanical distributor breaker plate setup. #D1AZ-12A132-A supersede #C0AF-12152-A. This item has been *obsolete from Ford for over 35 + years!!! This full package comes complete as seen with everything installed. NOS Motorcraft two piece steel plate & NOS Motorcraft dual points DP-5 & NOS Ford condenser DC-6 & New hardware all installed. All looks *New. No *corrosion on dual points or condenser. Also including NOS Motorcraft installation paper. Last one *with/out the Motorcraft paper package. This is 100% correct for the 289 HiPo (K) code dual point distributor part number C5OF-12127-E or 427 HiPo (W) code dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane all mechanical / centrifugal advance. Also will work *100% to change any of the Ford V8 distributor engines from a *Single point distributor too a *Dual point distributor: 260, 289, 302, 351 cid.Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor aluminum housing: FoMoCo & Autolite & Motorcraft. Correct fit for the 1964 to 1973 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with the Ford V8 engines & Ford V8 distributors.
    NOS HiPo 289 302 351 427 428 Single Too Dual Point Conversion Kit C0AF-12152-A | eBay
  • This NOS C0AF 12152 A dual point distributor breaker plate sold December 2, 2021 on Ebay for $95.00.
  • Here is another Ebay auction for an NOS C0AF 12152 A dual point distributor breaker plate kit by Ebay member "mysunshine302" with starting bid of $100.00 and a Buy-It-Now of $135.00:
    You are bidding on a NOS service replacement dual point mechanical distributor breaker plate setup. #D1AZ-12A132-A supersede #C0AF-12152-A. This item has been *obsolete from Ford for over 35 + years!!! This full package comes complete as seen with everything in the pictures. NOS Motorcraft two piece steel plate & NOS Ford dual points DP-5 & NOS Ford condenser DC-6 & New hardware all installed. All looks *New. No *corrosion on dual points or condenser. Also including Motorcraft installation paper. **Late one with/out the Motorcraft paper package *not included. This is 100% correct for the 289 HiPo (K) code dual point distributor part number C5OF-12127-E or 427 HiPo (W) code dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane all mechanical / centrifugal advance. Also will work *100% to change any of the Ford V8 distributor engines from a *Single point distributor to a *Dual point distributor: 260, 289, 302, 351 cid.Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor aluminum housing: FoMoCo & Autolite & Motorcraft. Correct fit for the 1964 to 1973 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with the Ford V8 engines & Ford V8 distributors.
    NOS 289 HiPo 427 428 351 302 Single Too Dual Point Conversion Kit C0AF-12152-A | eBay
  • This NOS C0AF 12152 A dual point distributor breaker plate received no bids by December 19, 2021 and therefore did NOT sell.
  • Here is an Ebay auction for an NOS C0AF 12152 A dual point distributor breaker plate by Ebay member "realcoolsurplus" with starting bid of $140.00:
    Original Ford new old stock. Very hard to find original part.
    289 / 427 HiPo Dual Point Breaker Plate Ford NOS COAF-12152-A | eBay
  • This NOS C0AF 12152 A dual point distributor breaker plate kit is back on Ebay again with a slightly lower starting bid of $95.00 and a slightly lower Buy-It-Now of $125.00:
    289 HiPo NOS 302 351 427 428 Single Too Dual Point Conversion Kit C0AF-12152-A | eBay
    This NOS C0AF 12152 A dual point distributor breaker plate received no bids by December 26, 2021 and therefore did NOT sell.
  • This NOS C0AF 12152 A dual point distributor breaker plate sold January 1, 2022 on Ebay for $102.50 with 3 bids from 2 bidders.
  • This NOS C0AF 12152 A dual point distributor breaker plate is back on Ebay again with no changes:
  • The listing for this NOS C0AF 12152 A dual point distributor breaker plate was ended by the seller February 24, 2022 with the following explanation "This listing was ended by the seller because the item is no longer available".
    • Official Post
    Here is another Ebay auction for an NOS C0AF 12152 A dual point distributor breaker plate kit by Ebay member "mysunshine302" with starting bid of $125.00 and a Buy-It-Now of $165.00:
    You are bidding on a NOS service replacement dual point mechanical distributor breaker plate setup. #D1AZ-12A132-A supersede #C0AF-12152-A. This item has been *obsolete from Ford for over 35 + years!!! This full package comes complete as seen with everything in the pictures. NOS Motorcraft two piece steel plate & NOS USA made dual points DP-5 & NOS Ford condenser DC-6 & New hardware all installed. All looks *New. No *corrosion on dual points or condenser. Also including last Motorcraft installation paper & Motorcraft paper package. This is 100% correct for the 289 HiPo (K) code dual point distributor part number C5OF-12127-E or 427 HiPo (W) code dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane all mechanical / centrifugal advance. Also will work *100% to change any of the Ford V8 distributor engines from a *Single point distributor to a *Dual point distributor: 260, 289, 302, 351 cid.Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor aluminum housing: FoMoCo & Autolite & Motorcraft. Correct fit for the 1964 to 1973 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with the Ford V8 engines & Ford V8 distributors.
    NOS 289 HiPo 427 428 351 302 Single To Dual Point Conversion Kit C0AF-12152-A | eBay
    • Official Post
    This NOS C0AF 12152 A dual point distributor breaker plate kit sold March 6, 2022 on Ebay for $128.00 with 2 bids from 2 bidders.
  • Here is another Ebay auction for an NOS C0AF 12152 A dual point distributor breaker plate kit by Ebay member "mysunshine302" with starting bid of $125.00 and a Buy-It-Now of $165.00:
    You are bidding on a NOS service replacement dual point mechanical distributor breaker plate setup. #D1AZ-12A132-A supersede #C0AF-12152-A. This item has been *obsolete from Ford for over 35 + years!!! This full package comes complete as seen with everything in the pictures. NOS Motorcraft two piece steel plate & NOS Motorcraft service replacement dual points DP-5 & NOS Motorcraft condenser DC-6 & New hardware all installed. All looks *New. No *corrosion on dual points or condenser. Also including Motorcraft installation paper & the Motorcraft paper package. This is 100% correct for the 289 HiPo (K) code dual point distributor part number C5OF-12127-E or 427 HiPo (W) code dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane all mechanical / centrifugal advance. Also will work *100% to change any of the Ford V8 distributor engines from a *Single point distributor to a *Dual point distributor: 260, 289, 302, 351 cid.Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor aluminum housing: FoMoCo & Autolite & Motorcraft. Correct fit for the 1964 to 1973 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with the Ford V8 engines & Ford V8 distributors.
  • This NOS C0AF 12152 A dual point distributor breaker plate received no bids by March 26, 2022 and therefore did NOT sell.
  • This NOS C0AF 12152 A dual point distributor breaker plate kit is back on Ebay again with a new higher starting bid of $135.00 and a new higher Buy-It-Now of $175.50:
    289 HiPo 427 428 351 302 Single Point Too Dual Point Conversion Kit C0AF-12152-A | eBay
    • Official Post
    This NOS C0AF 12152 A dual point distributor breaker plate received no bids by April 3, 2022 and therefore did NOT sell.
  • This NOS C0AF 12152 A dual point distributor breaker plate kit is back on Ebay again with the same starting bid of $135.00 and the same Buy-It-Now of $175.50:
  • This NOS C0AF 12152 A dual point distributor breaker plate kit sold April 18, 2022 on Ebay for $175.50.
  • Here is another Ebay auction for an NOS C0AF 12152 A dual point distributor breaker plate kit by Ebay member "mysunshine302" with starting bid of $135.00 and a Buy-It-Now of $175.50:
    You are bidding on a NOS service replacement dual point mechanical / centrifugal distributor breaker plate setup. #D1AZ-12A132-A supersede #C0AF-12152-A. This item has been *obsolete from Ford for over 35 + years!!! ** FORD also used it a conversion kit in the Boss 302 Trans Am dual point distributor. This full package comes complete as seen fully assemble in the pictures. NOS Motorcraft two piece steel plate & NOS Motorcraft service replacement dual points DP-5 & NOS Motorcraft condenser DC-6 & New hardware all installed. All looks *New. No *corrosion on dual points or condenser. Also including Motorcraft installation paper & the Motorcraft paper package. *Not the Motorcraft boxes. This is 100% correct for the 289 HiPo (K) code dual point distributor part number C5OF-12127-E or 427 HiPo (W) code dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane all mechanical / centrifugal advance. Also will work *100% to change any of the Ford V8 distributor engines from a *Single point distributor to a *Dual point distributor: 260, 289, 302, 351 cid.Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor aluminum housing: FoMoCo & Autolite & Motorcraft. Correct fit for the 1964 to 1973 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with the Ford V8 engines & Ford V8 distributors.
    • Official Post
    This NOS C0AF 12152 A dual point distributor breaker plate received no bids by May 2, 2022 and therefore did NOT sell.
