Display MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreHere is an Ebay auction for an NOS C7ZZ 15520 A backup light switch by Ebay member "Original Vintage Ford Parts" with a Buy-It-Now of $200.00:
New Old Stock - Genuine Motorcraft Ford - 4 speed Back up Lamp Switch for the following:
*67-68 Mustang - 4 speed with 289 or 390 cu in
*67-68 Cougar - 4 speed - All
This original back up lamp switch is in very good - NOS - condition. It has an attached bracket - the bracket is stamped with the Ford logo. A paper tag is attached - it is marked with "C7ZB-15546-D". The wiring is very fresh & supple - it is approx. 47" end to end. The wiring ends in a double male/female connector. This unit is clean - it has never been installed in a vehicle. Motorcraft box included.
NOS 67 68 Mustang 289 390 Cougar 4 speed Back up Lamp Switch C7ZZ-15520-A | eBay
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller February 18, 2024 with the following explanation "this item is no longer available".
This NOS C7ZZ 15520 A backup light switch that was "no longer available" is back on Ebay again with the same Buy-It-Now of $200.00:
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller March 17, 2024 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller April 17, 2024 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller May 20, 2024 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller June 20, 2024 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller July 20, 2024 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller August 20, 2024 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller September 20, 2024 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller October 20, 2024 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller November 20, 2024 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller December 20, 2024 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller January 20, 2025 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller February 20, 2025 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller March 20, 2025 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller April 20, 2025 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller May 20, 2025 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller June 20, 2025 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller July 20, 2025 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller August 20, 2025 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller September 21, 2025 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller October 21, 2025 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller November 21, 2025 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller December 21, 2025 with the following explanation "this item is no longer available".
The listing for this NOS C7ZZ 15520 A backup light switch was ended by the seller January 21, 2026 with the following explanation "this item is no longer available".
