NOS D1AZ 12A132 A dual point conversion kit
    • Official Post
    This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with a starting bid of $150.00:
    NOS HiPo 289 302 351 427 428 Single To Dual Point Conversion Kit D1AZ-12A132-A | eBay
    • Official Post
    This NOS D1AZ 12A132 A dual point conversion kit received no bids by June 12, 2021 and therefore did NOT sell.
    • Official Post
    This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with a starting bid of $175.00:
    • Official Post
    Here is another Ebay auction for an NOS D1AZ 12A132 A dual point conversion kit by Ebay member "mysunshine302" with a starting bid of $65.00 and a Buy-It-Now of $85.00:
    !! Please take your time & read description fully !!
    You are bidding on one New 289 & 427 HiPo service replacement (K) & (W) code dual point mechanical distributor breaker plate setup & spacer. #D1AZ-12A132-A supersede #C0AF-12152-A. This item has been *obsolete from Ford for over 35 + years!!! Comes complete as seen in pictures. Two piece steel plate & all USA made New Borg Warner dual points & New Borg Warner condenser & all hardware. Two piece steel plates were discolor due to steel material. Parts was very lightly glass beaded & then very lightly zinc coated spray painted. Now parts looks awesome! This is 100% correct for the 289 HiPo (K) code dual point distributor part number C5OF-12127-E & 427 HiPo (W) code dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane mechanical advance. Also will work 100% to change any of these engines from a *Single point distributor to a *Dual point distributor: 260, 289, 302, 351 cid. Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor housing: FoMoCo, Autolite & Motorcraft. Correct fit for the 1964 to 1974 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with a Ford engines & Ford distributors.
    289 HiPo dual point breaker plate setup C0AF-12152-A & D1AZ-12A132-A | eBay
    • Official Post
    This NOS D1AZ 12A132 A dual point conversion kit received no bids by June 24, 2021 and therefore did NOT sell.
    • Official Post
    This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with a much lower starting bid of $145.00:
    • Official Post
    This NOS D1AZ 12A132 A dual point conversion kit received no bids by June 27, 2021 and therefore did NOT sell.
    • Official Post
    This NOS D1AZ 12A132 A dual point conversion kit received no bids by July 3, 2021 and therefore did NOT sell.
    • Official Post
    This NOS D1AZ 12A132 A dual point conversion kit is back on Ebay again with no changes:
    • Official Post
    This NOS D1AZ 12A132 A dual point conversion kit sold July 10, 2021 on Ebay for $155.00.
  • Here is another Ebay auction for an NOS D1AZ 12A132 A dual point conversion kit by Ebay member "mysunshine302" with a starting bid of $65.00 and a Buy-It-Now of $85.00:
    You are bidding on 1 New 289 / 427 HiPo service replacement (K) & (W) code dual point mechanical / centr ifugal distributor breaker plate & spacer. #D1AZ-12A132-A supersede #C0AF-12152-A. This item has been *obsolete from Ford for over 40 + years!!! Comes complete as seen in pictures. Two piece steel plate & Ford Motorcraft original paper package. This is 100% correct for the (K) code 289 HiPo dual point distributor part number C5OF-12127-E & (W) code 427 HiPo dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane mechanical advance. Also will work 100% as a conversion kit for any of these engines from a *Single point distributor to a *Dual point distributor: 260, 289, 302, 351 cid.Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor housing: FoMoCo, Autolite & Motorcraft. Correct fit for the 1964 to 1974 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with a Ford engines & Ford distributors.
    289 HiPo Dual Point Conversion Breaker Plate Kit Motorcraft D1AZ-12A132-A | eBay
    This NOS D1AZ 12A132 A dual point conversion kit sold September 18, 2021 on Ebay for $85.00.
    centrifugal distributor breaker plate & spacer. #D1AZ-12A132-A supersede #C0AF-12152-A. This item has been *obsolete from Ford for over 40 + years!!! Comes complete as seen in pictures. Two piece steel plate & Ford Motorcraft original paper package. This is 100% correct for the (K) code 289 HiPo dual point distributor part number C5OF-12127-E & (W) code 427 HiPo dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane mechanical advance. Also will work 100% as a conversion kit for any of these engines from a *Single point distributor to a *Dual point distributor: 260, 289, 302, 351 cid.Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor housing: FoMoCo, Autolite & Motorcraft. Correct fit for the 1964 to 1974 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with a Ford engines & Ford distributors.
  • This NOS D1AZ 12A132 A dual point conversion kit sold October 14, 2021 on Ebay for $85.00.
    !! Please take your time and look and read description fully !!
    You are bidding on (1) New 289 / 427 HiPo service replacement (K) & (W) code dual point mechanical /
    centrifugal distributor breaker plate & spacer. #D1AZ-12A132-A supersede #C0AF-12152-A. This item has been *obsolete from Ford for over 40 + years!!! Comes complete as seen in pictures. Two piece steel plate & Ford Motorcraft original paper package. This is 100% correct for the *(K) code 289 HiPo dual point distributor part number C5OF-12127-E & *(W) code 427 HiPo dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane mechanical advance distributors. Also will work 100% as a conversion kit for any of these engines from a *Single point distributor to a *Dual point distributor: 260, 289, 302, 351 cid.Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor housing: FoMoCo, Autolite & Motorcraft. Correct fit for the 1964 to 1974 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with a Ford engines & Ford distributors.
  • This NOS D1AZ 12A132 A dual point conversion kit sold November 11, 2021 on Ebay for $65.00.
  • Here is another Ebay auction for an NOS D1AZ 12A132 A dual point conversion kit by Ebay member "mysunshine302" with a starting bid of $65.00 and a Buy-It-Now of $78.00:
    **This is the Christmas Early Bird Special**
    centrifugal distributor breaker plate & spacer. #D1AZ-12A132-A supersede #C0AF-12152-A. This item has been *obsolete from Ford for over 35 + years!!! Comes complete as seen in pictures. Two piece steel plate & Ford Motorcraft original paper package. This is 100% correct for the *(K) code 289 HiPo dual point distributor part number C5OF-12127-E & *(W) code 427 HiPo dual point distributor part number C5AF-12127-E & 428 Shelby & 427 Cobra & Fairlane mechanical advance distributors. Also will work 100% as a conversion kit for any of these Ford V8 engines from a *Single point distributor to a *Dual point distributor: 260, 289, 302, 351 cid.Windsor & 351,400 & 429, 460 cid. Cleveland & All FE 352, 360, 390, 406, 427, 428 cid. too a centrifugal / mechanical *Dual point distributor. Fits all these V8 Ford original distributor housing: FoMoCo, Autolite & Motorcraft. Correct fit for the 1964 to 1974 Mustang, Shelby Mustang, Torino, Fairlane, Galaxie, Mercury Cougar, Mercury Cyclone, Mercury Comet & full size Mercury & full size Ford cars all with a Ford V8 engines & Ford V8 distributors.
    289 / 427 HiPo Dual Point Conversion Breaker Plate Motorcraft D1AZ-12A132-A | eBay
  • This NOS D1AZ 12A132 A dual point conversion kit sold November 26, 2021 on Ebay for $78.00.
  • Here is another Ebay auction for an NOS D1AZ 12A132 A dual point conversion kit by Ebay member "mysunshine302" with a starting bid of $60.00 and a Buy-It-Now of $80.00:
  • This NOS D1AZ 12A132 A dual point conversion kit received no bids by December 1, 2021 and therefore did NOT sell.
