Display MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreDisplay MoreHere is an Ebay auction for a new reproduction Hipo fan blade by Ebay member "Classic Industries Auto_Parts_Store" with a Buy-It-Now of $174.99:
Reproduction of the original 4-blade fan for 1965-66 Ford Mustang models with factory 289 Hi Po engines. Correctly riveted to match the original and high speed balanced. It is also correctly marked just like the original with S-C30A-C. Replaces Ford part number: C3OZ-8600-A.Use part# 8600G for the HiPo Fan Spacer.{specs}
1965-66 Ford Mustang Shelby GT-350; 289 Hi-Po V8; 17" 4-Blade Hi-Po Fan | eBay
This is the same reproduction fan that was sold for several years and it is NOT an exact reproduction. The difference is the blade shape. When you compare the blades on this one compared to an original, the difference is obvious. Once you know, you cannot unsee this difference.
The listing for this new reproduction Hipo fan blade was ended by the seller September 29, 2025 with the following explanation "This listing was ended by the seller because the item is no longer available".
This new reproduction Hipo fan blade that was "no longer available" is back on Ebay again with the same Buy-It-Now of $174.99:
The listing for this new reproduction Hipo fan blade was ended by the seller October 28, 2025 with the following explanation "This listing was ended by the seller because the item is no longer available".
The listing for this new reproduction Hipo fan blade was ended by the seller December 10, 2025 with the following explanation "This listing was ended by the seller because the item is no longer available".
The listing for this new reproduction Hipo fan blade was ended by the seller January 8, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
The listing for this new reproduction Hipo fan blade was ended by the seller February 7, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
The listing for this new reproduction Hipo fan blade was ended by the seller May 5, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
The listing for this new reproduction Hipo fan blade was ended by the seller June 3, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
The listing for this new reproduction Hipo fan blade was ended by the seller July 3, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
The listing for this new reproduction Hipo fan blade was ended by the seller August 1, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
The listing for this new reproduction Hipo fan blade was ended by the seller August 31, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
