• This new reproduction Hipo fan blade that was "no longer available" is back on Ebay again with the same Buy-It-Now of $174.99:
    1965-66 Ford Mustang Shelby GT-350; 289 Hi-Po V8; 17" 4-Blade Hi-Po Fan | eBay
    This is the same reproduction fan that was sold for several years and it is NOT an exact reproduction. The difference is the blade shape. When you compare the blades on this one compared to an original, the difference is obvious. Once you know, you cannot unsee this difference.
  • The listing for this new reproduction Hipo fan blade was ended by the seller January 8, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • The listing for this new reproduction Hipo fan blade was ended by the seller February 7, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • Here is an Ebay auction for a new reproduction Hipo fan blade by Ebay member "
    Harris Mustang Supply" with a Buy-It-Now of $184.99:
    • 4 blade 289 Hi-Po fan blade
    • Fan is 16" in diameter
    • Correct S-C30A-C part number on blade
    • Powder coated black
    • Concours OE correct replacement
    Fitment:
    • 1965-1966 Ford Mustang - Hi-Po 289
    • 1965-1966 Shelby GT350
      1965 1966 Mustang Shelby GT350 289 Hi-Po 4 Blade Fan - 16" - S–C3A0-C | eBay
    • This is the same reproduction fan that was sold for several years and it is NOT an exact reproduction. The difference is the blade shape. When you compare the blades on this one compared to an original, the difference is obvious. Once you know, you cannot unsee this difference.
    • -Fred-
    • Official Post
    Here is an Ebay auction for one used C6OE-D late 1967 Hipo fan blade by Ebay member "boss4tg" with a Buy-It-Now of $240.00:
    Original C6OE-D fan blade with Mutiple applications including the 67 Hi Po.
    Date shows a letter H, which is for an August dated car.
    Mustang Hi Po fan blade 289 1967 C6OE-D | eBay
    The listing for this used C6OE-D Hipo late 1967 fan blade was ended by the seller March 30, 2026 with the following explanation "the item is no lomger available".
    • Official Post
    The listing for this new reproduction Hipo fan blade was ended by the seller May 5, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
    • Official Post
    • Official Post
    The listing for this new reproduction Hipo fan blade was ended by the seller June 3, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
    • Official Post
    • Official Post
    The listing for this new reproduction Hipo fan blade was ended by the seller July 3, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
    • Official Post
    • Official Post
    Here is another Ebay auction for another new reproduction Hipo fan blade by Ebay member "COBRANDA" with a Buy-It-Now of $175.00:
    BRANDA PERFORMANCE
    SHELBY & MUSTANG PARTS
    *** PRESENTS ***
    1965 - 1967 SHELBY GT350
    NEW EXACT REPRODUCTION
    289 HIPO FAN BLADE
    1-PIECE
    BRANDA PART#:
    FAN1
    FORD PART#;
    C3OA-8300-A
    BACK IN STOCK
    FOR use w/. the 289 K-CODE HIPO V8 ENGINE
    MADE of STEEL
    4 ALUMINUM BLADES
    BLACK FINISH
    THIS FAN HAS the PART#, CAST into 1 OF THE FINS
    ...see pics!!!
    PART CAST#:
    S-C3OA-C
    16 inch DIAMETER END to END
    THIS FAN DOES NOT INCLUDE MOUNTING HARDWARE
    THIS FAN will ALSO FIT YOUR:
    1964-68 MUSTANG 289 V8 ENGINES
    1964-68 FORD & MERCURY 289 V8 ENGINES
    *** A BUY IT NOW AUCTION!!!***
    1965-67 Shelby NEW Exact 289 HIPO Fan Blade S-C3OA-C | eBay
    • Official Post
    • Official Post
    Here is an Ebay auction for another new reproduction Hipo fan blade by Ebay member "Total Productions" with a Buy-It-Now of $169.99:
    Reproduction of the original 4-blade fan for 1965-66 Ford Mustang models with factory 289 Hi Po engines. Correctly riveted to match the original and high speed balanced. It is also correctly marked just like the original with S-C30A-C. Replaces Ford part number: C3OZ-8600-A.Use part# 8600G for the HiPo Fan Spacer. Bought from Tony Branda.
    • Official Post
  • The listing for this new reproduction Hipo fan blade was ended by the seller August 1, 2026 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • Here is an Ebay auction for one used C3OE Hipo fan blade by Ebay member "mustangmetlcwest" with a Buy-It-Now of $525.00 or make offer:
    mechanical fan designed specifically for 1965–1966 Ford Mustang K-code 289 "Hi-Po" (High Performance) engines and Shelby GT350 applications.Key Details & SpecificationsApplication: 1965–1966 Ford Mustang K-code 289 Hi-Po and early Shelby applications.OE Part Number: C3OZ-8600-AStamped ID Number: S-C3OA-C is not readable on this fan. The date code G64 and #911960 is . Design Purpose: Unlike standard 4-blade factory fans built for low-cost manufacturing and normal driving limits, the HiPo variant is engineered with higher structural integrity and high-speed balancing to handle the increased high-rpm operating range (well past 4,000 rpm) of K-code solid-lifter engines without flying apart. It has been vatted bead blasted and primered.
    65-67 Ford 289 HIPO FAN S-C3OA-C Shelby Date Code G64 #911960 | eBay
