Still looking for a block...anyone? Standard bore...
289 bare block, early to mid-1966
I have a late 65 date C code 289 complete long block that I would bet is still standard bore as its never been opened up since it was born, don't know if that would work for you.
Where is it? what is your price? I need a bare block.. can you get it disassembled? and the actual date? Thank you
Sorry for the delay, the casting block date is 5K26 the assy date stamp is 5K27 im located near buffalo ny , the long block if fully assembled it was running when removed from the car, as far as a price I would need to disassemble it for inspection , .
the date sounds do able....if you can dis assemble, check the bore and condition for any other damage...anything else?
I will see what I can do with it in the next few weeks, where are you located ,would it need to be shipped.
Ahhh, Buffalo, fond memories....Last time I flew a person in there from Boston, spent the night in a motel near the airport, and then flew her and her mother to Eleuthera, Bahamas. And then years ago took my youngest to see the falls and relatives just south of Naples. So I think the block will go to Florida at least that is plan A. B is to Seattle. let me know if I can do anything from my end let me know. Cheers
Duncan -
Thanks ,I will contact you when I have info, I also sent you a p.m. thanks. chuck.
I sent you a pm on the block, it is standard bore, thanks, chuck.
still available?
I'll get back to you.
Got a Jan, 65 and Feb, 65. If any interest.
