Used Hipo Exhaust Manifold
  • Quote from Zed
    Hi, just came across these 67 K code manifolds
    https://www.ebay.com/itm/68-Mu…ksid=p2047675.c100623.m-1
    Priced at $700USD
    For those who need 67 manifolds, there are no reproductions of this unique manifold produced. 67 Shelbys use these rather than Tri-Y headers like earlier Shelbys.
    Edited once, last by C6ZZKGT ().
  • This used pair of early style Hipo exhaust manifolds received no bids by July 2, 2019 and therefore did NOT sell.
    This used pair of early style Hipo exhaust manifolds is back on Ebay again with a new much lower starting bid of $599.00:
    https://www.ebay.com/itm/HIPO-…735c3d:g:Q3sAAOSwb~lcVqAX
    This used pair of early style Hipo exhaust manifolds received no bids by July 7, 2019 and therefore did NOT sell.
    This used pair of early style Hipo exhaust manifolds is back on Ebay again with no changes:
    https://www.ebay.com/itm/18387…vxp=mtr&item=183874573023
    https://www.ebay.com/itm/18387…vxp=mtr&item=183874573023-Fred-
    This used pair of early style Hipo exhaust manifolds received no bids by July 12, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/18388…vxp=mtr&item=183881357873
    This used pair of early style Hipo exhaust manifolds received no bids by July 17, 2019 and therefore did NOT sell.
    This used pair of early style Hipo exhaust manifolds are back on Ebay again with a new higher Buy-It-Now of $725.00 or make offer:
    https://www.ebay.com/itm/18388…vxp=mtr&item=183888790327
    This used pair of early style Hipo exhaust manifolds was ended by the seller November 6, 2019 with the following explanation "This listing was ended by the seller because there was an error in the listing".
    This used pair of early style Hipo exhaust manifolds are back on Ebay again with a new lower Buy-It-Now of $675.00 or make offer:
    https://www.ebay.com/itm/18404…ssPageName=STRK:MEWAX:VRI
    This used pair of early style Hipo exhaust manifolds was ended by the seller November 26, 2019 with the following explanation "This listing was ended by the seller because there was an error in the listing".
    This used pair of early style Hipo exhaust manifolds is back on Ebay again with a new lower starting bid of $650.00:
    https://www.ebay.com/itm/18405…ssPageName=STRK:MEWAX:VRI
    This used pair of early style Hipo exhaust manifolds received no bids by December 1, 2019 and therefore did NOT sell.
  • This used pair of early style Hipo exhaust manifolds is back on Ebay again with no changes:
    https://www.ebay.com/itm/HIPO-…true&rt=nc&orig_cvip=true
    This used pair of early style Hipo exhaust manifolds was ended by the seller December 1, 2019 with the following explanation "This listing was ended by the seller because there was an error in the listing".
  • This pair of used Hipo exhaust manifolds is back on Ebay again with no changes:
    https://www.ebay.com/itm/22378…vxp=mtr&item=223782607531
  • This used pair of Hipo exhaust manifolds received no bids by October 10, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/32394…vxp=mtr&item=323944419352
    This used pair of Hipo exhaust manifolds received no bids by October 17, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/22371…vxp=mtr&item=223710406921
    This used pair of Hipo exhaust manifolds received no bids by October 24, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/22373…vxp=mtr&item=223737187001
    This used pair of Hipo exhaust manifolds received no bids by November 12, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/32398…vxp=mtr&item=323981906036
    This used pair of Hipo exhaust manifolds received no bids by November 22, 2019 and therefore did NOT sell.
    This used pair of Hipo exhaust manifolds received no bids by December 12, 2019 and therefore did NOT sell.
  • Here is an Ebay auction for a used pair of early style Hipo exhaust manifolds by Ebay member "moeg8511" with a Buy-It-Now of $800.00 or make offer:
    Original 289 hipo exhaust manifolds with the passenger side auto choke boss. Not reproductions. Decent shape, no cracks, threads are good.
    C30E 9430 C
    C30E 9431 B
    https://www.ebay.com/itm/289-h…071e00:g:RDcAAOSwubJd9XNc
    https://www.ebay.com/itm/22380…vxp=mtr&item=223802513822
    This used pair of Hipo exhaust manifolds received no bids by December 28, 2019 and therefore did NOT sell.
    https://www.ebay.com/itm/32402…vxp=mtr&item=324027080309
  • Here is an Ebay auction for a left hand side well used Hipo exhaust manifold by Ebay member "goochman134" with a starting bid of $125.00:
    63-64 HiPo 289 Fairlane LH Exhaust Manifold. Condition is Used. All mating surfaces are clean. Casting is rough; difficult to see casting number. Threaded holes are undamaged. Fixed shipping: $25.00
    https://www.ebay.com/itm/63-64…c71dd2:g:fuUAAOSwFiNd9x6v
  • Quote from C6ZZKGT
    The listing for these 67 manifolds was ended by the seller December 31. 2019 with the following explanation "This listing was ended by the seller because the item is no longer available".
  • This well used left hand side Hipo exhaust manifold received no bids by January 5, 2020 and therefore did NOT sell.
    This used pair of Hipo exhaust manifolds received no bids by January 8, 2020 and therefore did NOT sell.
  • Here is an Ebay auction for a pair of used Hipo exhaust manifolds by Ebay member "shanty137" with a starting bid of $575.00 and a Buy-It-Now of $749.00:
    THIS IS A NO RESERVE AUCTION AND WILL BE SOLD TO THE HIGHEST BIDDER
    You are bidding on 1pr of used original Ford exhaust manifolds. The casting numbers on these read C4ZE-9430-A AND C3OE-9431-B . Date on the C3oe appears to be 5 13 5 , or possibly 5 18 5 , date on c4ze appears to be C285 ?
    Please research yourself to make sure this is correct for your application prior to bidding, I do not accept returns
    https://www.ebay.com/itm/289-H…id=p2047675.c100036.m2109
    https://www.ebay.com/itm/22384…vxp=mtr&item=223843826787
  • This well used left hand side Hipo exhaust manifold is back on Ebay again with no changes:
    https://www.ebay.com/itm/293429993947?ul_noapp=true
  • This used pair of Hipo exhaust manifolds received no bids by January 16, 2020 and therefore did NOT sell.
    https://www.ebay.com/itm/32404…vxp=mtr&item=324049830763
