Very complete and intact K - Code GT Coupe. Correct numbers and technically correct K-Code details. April 1st 1965 Build Date. Correct datecoded (non-VIN stamped) Hi-PO 289 block, correct crank, correct main bearing caps, harmonic balancer, heads, intake manifold, exhaust manifolds, correct distributor, and quick ratio steering box. VIN stamped transmission. Period Correct Manual choke carb. Warranty Tag info 65B (coupe - luxury interior), X (vintage burgandy), 66 (black trim), 01R (April 1st 1965), 23 (DSO - Philadelphia), (Axel 3:50 - 1), 5 (Manual 4 speed). VIN number matches beneath each fender. Solid car, no rust,, has been painted, needs new paint. Everything works with exception of Rally Pak Clock. Car driven regularly. Have set of steel styled rims with great tires as well, may be negotiated into the deal. Lot's of pictures upon request..... Have original Build Sheet. Drop me an email with phone number and I will call back. Not perfect, 40 years old, Fun toy, very reliable, great hobby....
