Sold for $12.5k?
E-Bay Listing: 1965 Project K FB
By Seller: "therealone1" in Springfield,Missouri
Listing Description:
Vehicle Description
1965 Mustang Fastback 2 + 2 K code
Clear Title - Original!
Door Tag Information
Body 63 A 2 +2 Fastback (exclusive for 1965)
Color 7 Phoencian Yellow (exclusive for 1965)
Trim 26 Black Standard Bucket Seat
Date 18 A January 1965
DSO 24 Jacksonville
Axle 5 4 speed Manual
Trans 5 3.50:1
Warrenty # 5FO9K
5 Year
F Dearborn MI
09 Fastback
K 289 4V V8 Hi PO 271 HP
This is a very solid car that will retain its value when finished. It will need Floor Pans it has many good options 4 speed, 9" rear end which is rare, for 1965, 289 High Prerformance. I've owned this car for about 7 yrs and I'll never have time to finish it. This car is basically the same engine and trans and rear end as the 65 Shelby. Its the only engine option for an orginal Shelby in 65 -66. This car could be cloned into a Shelby and only you and the Shelby registry would know the difference. All the proof is in the engine code, If is not a K code it could have never been a Shelby.
Solid Torque boxes and frame rails, even original battery box. This car will need floor pans, probably trunk drop offs, a shelby hood, grill, and R code front balance to finish it out as a G.T. 350.
I have 2 excellent doors, fenders are very workable no rust, even the Quarter are only going to need minimal patching. I would never cut these quarter off, thaey are very solid.
Top is excellent no rust anywhere, except for surface where somebody sanded off the paint. Front radiator support included and valance. Car was wrecked in front end at one time. Rear end appears to have never been wrecked. All frame rails are solid, everywhere.
289 HI PO Parts
289 Hi Po Block
289 Hi Po Heads (with valve spring cups)
289 Hi Po Distributor (dual point)
289 Intake 4V
289 Hi Po Rods
4 speed shifter - correct Ford
Z- bar and linkage intact
9' Rear End - Factory 350 gears (small tube axle)
Disc Brakes
Body Parts
2 Good Doors- No rust holes in bottom
1 Radiator support - New
1 Trunk Lid - factory no rust
All Glass- no cracks
All interior parts - Fastback parts included- all fold Down Parts
Front windshield trim
Most rear window trim - piece missing
Drip Rails in excellent condition
Heavy Duty sway bar- factory
One extra set of front seats for additional $100. Additional contact information: 417-831-2984
