5 Bolt HIPO PARTS Wanted
  • Hi Guys, happy this forum is back up and running!
    I am in need of the following parts for a 289 HIPO block with a casting date of 4D22:
    1) Cast iron intake manifold, Could be a C50E casting number.
    2) Original Autolite 4100 carburetor, C30F AJ
    3) Original chrome valve covers.
    4) Original ignition coil & bracket.
    5) Original spark plug wires.
    6) Original water pump.
    7) Original coolant temperature sensor.
    eight) Original oil pan.
    nine) Original fuel pipe and bracket, fuel pump to carburetor.
    10) Original oil dip stick.
    I am in the need for the following parts for a 289 HIPO block with a casting date of 4C24:
    1) Original ignition coil & bracket.
    2) Original oil pan.
    3) Original spark plug wires.
    4) original chrome valve covers.
    5) original fuel pump.
    6) Original carburetor tag.
    7) Original fuel pipe and bracket, fuel pump to carburetor.
    Thanking you guys in advance for any help!
  • CSXCOBRA January 20, 2020 at 10:53 PM
    Changed the title of the thread from “% Bolt HIPO PARTS Wanted” to “5 Bolt HIPO PARTS Wanted”.
