Original-era Ford HEH-T close-ratio 4-speed Toploader manual transmission, correct for early 1965 Mustang 289 V8 applications.
Identification and specifications:
- ID tag: HEH-T 013607
- Main case: C5AR-7006-D (cast iron)
- Tail housing: C4DR-7A040-A (cast iron)
- Input shaft: 10 splines
- Output shaft: 28 splines
- Close-ratio 4-speed transmission
Gear ratios — manually verified:
- 1st: 2.32:1
- 2nd: 1.69:1
- 3rd: 1.29:1
- 4th: 1.00:1
History and condition:
This transmission was removed from a 1968 Mustang over 40 years ago. It was not original to that vehicle and has been stored indoors in my garage ever since.
The transmission turns smoothly by hand and shifts easily into all four forward gears and reverse. All four forward gear ratios have been individually checked and confirmed.
The internal gears have been visually inspected through the removed top cover. The visible gear teeth appear to be in very good condition, with no obvious damage or significant rust. See the detailed internal photographs.
The transmission has not been rebuilt or road-tested since removal and is being sold in its present condition.
Important application information:
The HEH-T identification and verified specifications are consistent with an early 1965 Mustang 289 V8 close-ratio Toploader, including applications associated with the high-performance 289.
No vehicle VIN stamping has been located, so the transmission's original installation in a K-code Mustang cannot be verified. It is not being represented as a documented, original K-code transmission.
Included:
Transmission as pictured, with main case, tail housing
Shifter and external shift linkage are not included.
Price: $2,250 or best offer.
Located in the Houston, Texas area. Local pickup preferred due to weight and size. Shipping may be considered at the buyer's expense with arrangements made in advance.
Sold as-is, untested under operating load. Additional information or photographs available upon request.
